Viewing 11 posts - 1 through 11 (of 11 total)
  • Easiest internally routed brake swap?
  • hunta
    New bike (2021 model) came with Shimano Deore brakes, with the rear internally routed. I’m not a massive fan of the levers and prefer the single finger SLX M675s I bought in 2012 and have fitted to another bike.
    Normally I’d swap them over in a jiffy, but I’m not wild about feeding the rear through the frame plus not 100% sure it’s long enough.
    Anyone know whether the levers are compatible and would be a straight swap if I leave the lines and calipers in situ?
    qwerty
    Don’t Shimano use two different brake lines? That’s why there two different olives and barbs BH59 & BH90, check what’s printed on the brake line outer?
    Personally I’d just swap the levers over, if your slick they should only need a lever bleed with the Shimano funnel.
    thols2
    As above, you need to check that the hose fittings are compatible with your levers.
    bikerevivesheffield
    Get a SRAM barb
    https://www.tredz.co.uk/.RockShox-Barb-Connector-Reverb-Stealth_77198.htm
    Join old line to new line and feed through
    paton
    coatesy
    Levers are a straight swap regardless of hose type, BH90 has a smaller bore, thus thicker wall, doubt anybody in the real world would ever know the difference.
    Agency_Scum
    After spending years ( it seems ) peering into frames held vertically in the workstand with a torch and steel eyebrow tweezers I suddenly said ” b0ll0cks to this ” and have since taped and zip-tied my brake and gear lines to the exterior of the bike and it feels LOVELY. I’m six and a half feet tall and a foot and a half wide so for me the aero argument is complete @rse. It’s so liberating going ” Ooh I need a new brake hose, that’ll take AT LEAST 15 minutes but I’ll have time to get a brew on. ” Bliss.
    thols2
    I honestly don’t understand why everyone doesn’t do this.
    Del
    Mainly because it looks fing awful?
    Would be really useful if manufacturers provided both types of routing so at least you’ve got a choice that doesn’t look shit.
    rockandrollmark
    Outer diameter for BH59 and BH90 is the same. I’d dare say you could use the existing hoses (with new olives) on your old levers without any bother.
    Yet another great example of “standards”.
    trail_rat
    I’ve always just fed a brake inner through the frame first and used that to pull the hose through…… Ever since doing orange patriots way back when for customers who also just ziptied and taped them to the outside -but then wanted to gouge their eyeballs out with how crap it looked.
    Road bikes with all in one stem/bar combos and internal routing are a different kettle of fish.Outer has to be mm perfect cut before you start much like splicing gauge fibre optics.
Thanks for popping by - why not stay a while?IT'S FREE
Sign up as a Singletrack Member and you can leave comments on stories, use the classified ads, and post in our forums, do quizzes and more.
Join us, join in, it’s free, and fun.
