Viewing 8 posts - 1 through 8 (of 8 total)
  • Dt Swiss hubs
  • Premier Icon canna
    Does any body know if you can get a 12 mm through axle for a Dt Swiss 240s hub ?
    Premier Icon BearBack
    12mm end caps probably.
    here
    Premier Icon canna
    They only fit the 350/370 hub I’m looking for some for a 240 hub
    Premier Icon packs
    I think you need these HWGXXX00S7564S
    According to Universal Cycles: “Compatible with 2015+ black 180 front hubs (QR or 15mm). Does not fit white 180 hubs. Also fits: XMC1200, Spline 1501, RR21 DiCut and RC Carbon wheels”
    The cap O.D. is 27mm, not 30mm like with HWGXXX00S7000S.
    Premier Icon canna
    Thanks I will have a look at that
    Premier Icon hatter
    For all DT spares, check here first:
    https://www.dtswiss.com/en/support/product-support
    Premier Icon nixie
    Front or rear. If front the version that takes up to 15mm or the 20mm version?
    Premier Icon Northwind
    If it’s a very old DT240, then the axle might need replacing- they pre-date the 12mm standard so some have a smaller hole. (and because they last forever, there’s still a few of these QR-only parts out there). Otherwise, as above, endcaps. You’ll need to sell a kidney but other’n that, ideal
