oikeith
@rusty I need to do my 350 rear hub bearings with fresh 6902’s, the official vid shows lots of unique tool required, did you have all of these or are some not actually needed?
There’s one unique tool you need to get to the centremost bearing, the one held in with the ratchet ring. Everything else can be done with sockets like most hubs, it’s just easier with the proper tools. And you can refit the seal using the freehub.
but not the official DT tool- it’s ironically a bit shit, it has a square end so you can’t easily put a socket on it to use a breaker bar or whatever, best you can do is clamp it in a vice. Bad design. Mine is an ebay special that has a 1/2 inch adaptor, way better but I now can’t find it online. There’s lots of 3rd party ones that have a hex end so you can stick a socket over, that’s the second best way. The ratchet takes some force so having a big breaker or an impact gun makes things simple.
Oh yeah lastly there’s a really good chance that your centre bearing doesn’t need changed at all and can just be left alone. 350s have cheaper bearings but they’re still decent and that bearing’s well protected. They’re not hubs that changing all the bearings at once is really the best way, if you’re diy’ing it, just do what’s needed.
