My two p.
Block paving fades, a lot more than you think and can look pretty shabby after only a few years, it will also require regular cleaning especially in shaded areas, also there’s plenty of lads who can chuck a few pavers down but the key to avoid dips and hollows mainly where you park is in good ground prep so do your research on who you use. In the Derbyshire area I can recommend only one lad who is spot on.
Patterned concrete is lovely if done right but my big fear with that is if you ever have any service problems, it does not patch and will forever upset you if the gas board come out to fix a leak etc
I like tarmac, weather’s well, and again if the ground prep is done right you will have no problems, some of the resin bonded stuff with say a double block paved border can look really good, saying that a standard well laid wearing course also looks good.
A simple gravel drive, again with good ground prep can also be a good cheaper solution, it will be noisy and require regular fettling though.
Various rules and regs planning wise regarding attenuation and or discharge of top water may also be a requirement IF you go through planning. All stuff that adds cost.
