they’re about all that will fit on an Uzzi so I’m stuck with it.
not twatted mine yet, but just had a quick look & see your point. Also, mine was super tight to fit behind the cranks, I had to file the tops off a couple of countersunk bolts to make everything clear each other.
What setting do you run the dropouts at?
Given you’re supposed to mount the roller at about 7-8 oclock, meaning the stinger sits higher than the bash guard you’ve presumably fitted, you have to be pretty unlucky to clout the stinger with something that didn’t get stopped by the bash?
the arm that holds the roller is about an inch to the right of the bash guard & I did **** mine on the last bike I had a stinger on – that was bb mounted tho, so it simply rotated a little until the chain was pushing on the swing arm. with a ISCG type I guess it’ll bend rather than move in the slots. as a precaution I tightened mine up in the most anticlockwise position it would fit. it’s only a few degrees, but it ‘might’ stop it bending :/
