JAG + 1/2.
You likely got some odd oxides developing on the braking surface. The friction behaviour may change as a result of this. The cause of friction is a hotly debated topic in my field. Otherwise, if you’re really dragging the brakes and it’s a hot day, perhaps you’ve had some recrystallisation due to tempering of the surface regions. Depending on which friction camp you’re in, a change in mechanical behaviour of the top surface may be a sufficient explanation.
However, friction is a product of a material pair (e.g. brake disc surface and brake pad). Changing pads may adjust the coefficient of sliding friction, although it may not.
I would bet that the most important thing to do is to have the correct pad and disc roughness (formed after being bedded in) and to have a suitable tribolayer on the interacting surfaces. The friction behaviour is likely due to an interaction between the metal disc surface region, metal disc bulk, pad surface region, pad bulk region and a corresponding tribofilm formed due to an aggressive sliding contact.
I don’t expect that to be very helpful!
