Viewing 9 posts - 1 through 9 (of 9 total)
  • DIY gurus: Garage door not closing as tiles too high
  • Premier Icon mattyfez
    So I want to chamfer the edges of a tile or two, hopefully negating the need to lift the tiles up or break them.
    My problem is a garage door that wont shut properly, I Have a tile cutter circular saw type thing, can you use these things free-style?
    The interior of the garage has a tiled floor which is slightly too high, just in one spot that I can tell, preventing the door from closing and locking properly.
    Thanks
    Hhh
    Premier Icon Flaperon
    There’s probably enough adjustment in the door itself or its mounts to fix this.
    I can only imagine going freestyle with a tile saw ending in tears or A&E, or both.
    Premier Icon nickjb
    I’d start with the door. If there isn’t enough adjustment then a diamond disk in the angle grinder.
    I cant see how to adjust it, its a basic mechanical garage door that locks on both sides
    Premier Icon fossy
    Cut the tiles away to the shut line, also serves as a water run off.
    All the fittings look riveted
    2020-09-26_06-20-15
    Premier Icon hols2
    Universal adjustment tool.
    Almost there… Just needs a bit more
    2020-09-26_07-02-15
    Premier Icon lesgrandepotato
    Just adjust the door with a hammer.
