• This topic has 154 replies, 71 voices, and was last updated 12 years ago by brew.
Viewing 40 posts - 41 through 80 (of 155 total)
  • Diy 900 lumen and 1800 lumen kits
  • trout
    Rightio got one ready to build up well nearly
    here is what will be in the kit
    ref the driver the H6flex is for battery voltages over 8.4 volts and under 20 volts and is a pricier driver .
    The Lflex is for the 8.4 volt batterys and will run off a DX Bastid
    battery if needed and a DX cable is available from me or DX
    You will need to be able to solder or have a mate that can
    and drill a few holes IE switch and cable entry
    also holes for screws to hold the leds down I will get some small self tappers and include in the kit for this purpose .
    the housing will be raw aluminuim and need sanding and finishing off
    if you want it to look a bit better
    If I do it then it costs a bit more 😉
    but if you are lazy you can just assemble it and go riding
    I will have this one built today and get a beam shot tonight .
    the single 900 lumen one will be half size and only use the Lflex driver and 3.7 volt battery
    tools needed to build will be
    soldering iron
    drill and bits
    wet and dry and fine wire wool if you wand to shine it up a bit .
    screw driver
    A Tube of this glue http://www.bostik.co.uk/diy/product/evo-stik/Serious-Glue/16 is one I have found to be an excellent and better product than silicon sealant
    I will probably include a tube in the kit to keep it easy .
    Stoner
    does it need any arctic silver or the like?
    I wish I didnt already have an LL – Id want to make up one of those.
    Maybe I could go into business putting them together for people who want an easy life? 😉
    trout
    Arctic alumina or silver epoxy can be used to glue the led stars in place
    instead of screws and compound forgot to mention thermal compound .
    lipseal
    Hi any idea on battery life for the 1800?
    plumbob
    Yep, very interested in the 1800 kit, especially with the upgrade on the case finish.
    Ian
    trout
    edited
    pascoa341
    Definitely interested in this! This actually looks do-able for an idiot like me :-).
    trout
    A quick run through a build sequence ( other peoples methods may vary )
    You have got your housing all shiny and shaped to your liking .
    it needs a thorough wash to get any swarf and grease off it
    and you are ready to start .
    as you see the 20 mm led star is 1 mm too big to fit top to bottom
    so a careful filing is required being mega careful not to knock the led dome off remove enough ali so it fits snug but don’t go right to the top and bottom solder pad as you don’t want them to short on the case .
    and before installing them in the case it is a good idea to tin the pads you are going to be using
    next to install the leds I have used Arctic alumina epoxy for speed
    but at £8 for a kit of the stuff you can drill and screw the stars to the heat sink and use some thermal paste .
    then connect your feed wires and pass them through to the rear .
    time to now fix the reflectors
    use some of the serious glue and make a ring round the leds
    being careful not to get any on the leds
    and fit the reflectors making sure to seat them level and wait for the glue to set .
    when it has set you can also fit the lexan cover using careful application of the glue around the ledge
    and maybe a bead around after the lexan is in place for added waterproofing .
    the Driver next and this applies to both H6flex and Lflex drivers
    when soldering wires to them you must make sure they dont protrude out the bottom as the driver needs a flat base for the thermal adhesive tape provided to fix it in the housing
    you will have drilled your backplate for the switch and what ever power entry you have chosen or bribed me to drill them I have used the Liberator connectors for this build .
    now it gets a bit fiddly when the connections are made
    remove on side of the protective covering and apply the tape to the driver base .
    remove the other side and insert in the case in your desired position
    the tape will not stick tight until you warm up the case with a hairdryer and carefully seat the driver flat .
    it is important the driver is well seated as it needs to be kept cool also.
    seal up the back with some of the glue and screws and job nearly done
    you now need to configure your driver using the instructions on the http://www.taskled.com site
    DeeW
    Chris,
    I’d be interested in a 1800 kit. Would be my 5th Troutie light!! Would seem a real shame to miss out on the next generation!
    Am I right in thinking these are going to be fairly narrow so perfect for helmet light?
    I’d be replacing my 3 x XPE R2 helmet light which although has a great throw, does gets pretty drowned out by my Liberator, but wouldn’t want to lose the throw of the XPE. 1800 be roughly twice as bright as the XPE?
    Dave
    PS went for a ride a couple of weeks back with 6 Trout creations between 4 of us: got a local monopoly going on here!
    bobblehat
    Nice, Chris!
    Couple of Q’s: Do you supply a piece of L angle or similar for the LED board? If so, do you supply the case with a tapped hole for the bar mount in the case or the L angle (or both)? Is this hole the primary means of holding the LED plate to the case?
    trout
    Dave
    Yes they are a good helmet beam and OMG bright
    beam shot when it gets dark tonight .
    Bobblehat
    no L angle in there it is an 8 mm thick lump of billet
    and an interference fit with some paste for good measure forced in with a gert big vice and then the M4 tapped hole is drilled into it so it aint going anywhere .
    liquid
    Looks great how do I order one? Thanks
    bigjim
    I kind of want one, I don’t need one, but I want one…
    bobblehat
    Thanks Chris, sounds good, looks good ….. tastes good and by golly it probably does you good as well! 🙂
    It’s the Mackeson Light!
    trout
    Beam shots at the MTBR settings
    low approx 280 lumens runtime from a 2.6 amp hour 14.8 v battery
    is approx 28 hours
    medium approx 560 lumens runtime from same battery 8 hours approx
    High approx 1800 lumens runtime as above battery 1 hour 40 mins
    other levels are available if you need to tweak runtimes
    stuey
    i love you
    Evesie
    Can you give me a price on a driver, LED’s & reflectors please. Hopefully if you are buying in bulk this would be better than what I could get the hardware for.
    cheers. (mail in profile)
    trout
    OK will have a workout tonight Evesie
    which driver ?
    Stuey. are you a fit female ?
    stuey
    I could be for you..
    <<Has selling led light made you a multi millionaire yet ?>>
    Is there a driver solution that allows for swapping between <8.4v and >8.4v ?
    trout
    not realy for a doube xml set up.
    H6Flex. for > 8.4. and. LFlex for. < 8.4.
    Multi billionaire really with a girl in every town
    FunkyDunc
    Trout – Did I miss it, but how much would the double set up be?
    I was looking at doing your 700 lumen lights…but now Im thinking!
    rc200f8
    will definatly have an 1800 kit from you
    bedmaker
    Is there a way of making the medium setting a bit higher? Say 1000 lumens ish for 4 hours ish on that battery?
    Probably more useful for singletrack stuff like that, with the full setting just for faster downhills and foxhunting. 🙂
    I’d take a kit if that were the case.
    bugpowderdust
    I’d definately be interested in an 1800 kit.
    mrcamel
    Slightly ot question, and you’ve probably done it already… but, how much longer would the casing of the single have to be to fit batteries in as well??
    Del
    put me down for a double then please.
    i may take a few singles, with the H6 >8.4V drivers, w/o cases too, for conversions, if that’s ok?
    see how the numbers work out.
    frogger
    These batteries seem like they would do the trick nicely!
    A123 from HobbyKing
    sam42
    I’m interested in some loose xmls on stars if you could hook me up troutie?
    FunkyDunc
    smudge
    Another neat light there Mr T 8)
    If anyone is after a purpose built 7.5V 4.4Ah Li-Ion Battery along with pouch, charger & mains lead.
    I will also include a mating lead for the light head.
    £63 inc p&p but limited availablility.
    Please email me for more information.
    Smudge
    Evesie
    Mr Trout,
    LFlex please – I like nice small battery packs.
    thesurfbus
    Put me down for a 1800 lumen kit, with a driver for a 12v battery.
    5thElefant
    Battery wise I was wondering if this would do?
    http://cgi.ebay.co.uk/12V-9800mAH-Portable-Li-ion-Rechargeable-Battery-Pack-/290532586412?pt=UK_ConsumerElectronics_Batteries_SM&hash=item43a51773ac
    £30 but is it likely to fail and blow up!
    I’ve got one of those. Works fine. Big old lump though. This pouch is a good fit for it.
    WorldClassAccident
    Chris – your website is down and I want need some of your finest lights.
    What have you got that will burn for 4-5 hours and bring down small aircraft?
    How much and how soon?
    email me if you don’t want to post up here.
    Clobber
    Put me down for a double running 15v please Chris.
    blast
    I will take a 1800 Lflex kit please .mail us with further instructions
    Simon
    Richie_B
    Interested in an 1800 with a H6Flex
    rc200f8
    Forgot to mention in an earlier post that I’d want an Lflex driver with the 1800 kit.
    Mail in profile.
    Iain
    trout
    Hello peeps had a horrific few days working 18 hours a day and falling asleep as soon as I get home so sorry for disappearing.
    got a price worked out for the double kits but with a change of optics as the reflector has a sharp cut off at the sides which I dont like so will be using Ledil Laura optics build will be just as easy so no worries there .
    as said before the housings will be rough machined and you will need to do a bit of finishing on it
    to build you will only need to get some thermal paste or thermal epoxy
    everything else will be included in the kit .
    I only have 2 of the H6flex`s in stock with more on order so will be a while before they arrive .
    I have 15 of the Lflexs in stock with more on order.
    prices are H6fex kit £95 posted ( battery > 8.4 volts )
    Lflex kit £85 posted ( Battery 8.4 volts )
    email me if you want one mail in profile
    rc200f8
    Hi Chris, mail sent
    Iain
The topic ‘Diy 900 lumen and 1800 lumen kits’ is closed to new replies.
