Home › Forums › Bike Forum › Did an FTP Test, what next?
- This topic has 73 replies, 28 voices, and was last updated 9 years ago by lazybike.
butterbeanFree Member
I had the opportunity to do an FTP test last night, which was quite unpleasant.
I did it out of curiousity, and partly because I have a desire to be a bit fitter, and wanted some sort of baseline to work from.
Looking at the table of champions, I seem to fair in the slightly lower middle.
I’m 188cm, ~81kgs & my FTP was 239W, which gives a W/KG of 2.9.
I guess that explains why I suck at climbing for starters!
Clearly I could lose a bit of weight (maybe 5-6kg) but I would also like to improve my power output.
I’m assuming if I improve the numbers, it will improve my general fitness etc? Sadly I don’t have the time to put more than 7-10 hours a week of training (which includes commuting) so I want it to be as effective as possible.
Has anyone done anything similar, manage to fit around a FT job? What sort of stuff did you do and what sort of improvements did you experience?
Completely arbitrary numbers but I guess maybe I would like to be ~75kg & 300w & see what difference it makes. Doesn’t seem too outrageous?
thomthumbFree MemberClearly I could lose a bit of weight (maybe 5-6kg) but I would also like to improve my power output.
focus on one and make the other secondry. I’d suggest power, whilst making small improvements to diet is the sensible way.
intervals on the turbo. Personally i would focus on 20MP – the rest goes hand in hand with it.
TurnerGuyFree MemberWas going to suggest Ping or Telnet, but can see that isn’t what’s wanted…
njee20Free MemberI guess that explains why I suck at climbing for starters!
Not really, FTP and climbing aren’t necessarily related. Someone like Tony Martin will have a fantastic FTP, but isn’t a great climber.
Agree that focusing on increasing power or losing weight is a good shout (although don’t lose sight of either), and there’s probably more to be gained by increasing your power, as that’s quite low.
No idea how ‘good’ you are now, but that would be a big change!
The-Swedish-ChefFree MemberGoing from 2.9Wkg to 4 would be quite a goal to reach, certainty achievable over a few years.
Number wise I guess that 4W/kg could potentially place you well up there in Expert class races, depending on your technique.
Along with your FTP value you most likely got HR values as well, whilst not as good as power, training with a HR monitor, even on a commute can increase your FTP.
Things like 2 * 20 mins, 4 * 15 or the like are classic sessions for this type of training goal, and potentially doable on a commute. Get yourself a HR monitor and train at those levels that you saw in your test.
dunmailFree MemberWell I’m 179cm and 83Kg, no idea what my FTP score is but I’m in the top ten of quite a few Strava segments both on and off-road so either everyone else doing those segments is cr** or I’m reasonably fit. One general rule from road cycling is take your height in inches and that should be your weight in kilogrammes but that’s for elite athletes and you could probably add 10% for most.
By far the most effective training for time constrained people are intervals but you need to really work at them.
LSFree Member7-10 hours a week is what most people have to work with! 300W at 75Kg is more than achievable and would make you average-to-good at a domestic level.
mattsFree MemberIf you want to improve your threshold power, the most effective training is to do threshold intervals. Steady state is mind-numbingly boring, and extremely hard on the trainer, so over-unders or suchlike can help to mix things up a bit.
Trainer Road is a great way to get you started with structured training.
DanWFree Member~75kg & 300w
Got to agree with Njee and Chef that that would be a pretty big improvement to be aiming for. Doable over quite a bit of time if you stuck to a consistent 7-10 hours a week of quality riding but most people struggle with consistency more than knowing what to do with those 7 hours.
TR is also great for the virtual power feature which gives you objective and instant feedback as to how hard (or not) you are actually doing various intervals which is key.
Personally, I would “raise the left and fill the right”, i.e. work to raise your critical power at the shorter durations while getting the long, easy rides in. Some good reading of practical, time crunched ideas here and here.
butterbeanFree MemberOk, i’m not too concerned about weight, i’m hardly a fat biffer, and I don’t want to end up looking malnourished. I’m sure if I start upping the intensity and keep eating the same i’ll naturally lose a bit anyway.
Understand, so for doing something like these, how hard should I be going? I have the HR data from the test too. Should doing these be going as hard as I went for the test?
I’ve got a few of the Sufferfest video’s as well, would doing something like downward spiral intervals be beneficial too?
Lastly, how many of these should I be doing a weeK? I commute mostly through urban areas so would like to keep that low intensity (for fear of life) and do most of the nasty stuff on the turbo.
All will have to be on an HRM, don’t have a power meter myself.
Edited to add – thanks for the input so far!
mattsFree MemberIf you don’t have a PM, then using the virtual power of Trainer Road is a really great way to structure your efforts. If you use one of their training plans, you will also have target effort levels for the workouts, and rest time planned in to your week.
If you want to train on your commute (which is what I do), then you need to find some places where you can ride hard without too many interruptions. I use Regent’s Park or if I have more time, a loop further out past my house near the M25. And for shorter efforts I do loops up and down Highgate Hill. The rest of the commute in and out I generally ride at an easy pace.
If you have training plan, then you can sub in some outdoor intervals for the ‘on’ days, and just ride super easy on the other days.
The-Swedish-ChefFree MemberUnderstand, so for doing something like these, how hard should I be going? I have the HR data from the test too. Should doing these be going as hard as I went for the test?
Well lets say your average HR for the 20 minute test was 160bpm, it started at 130 as you were already warmed up and peaked at 165, for example.
You’d want to do those intervals averaging just under 160, in what is called the sweet spot, not too hard that you can’t concentrate on traffic and do a productive days work afterwards, but probably quite a bit faster/harder than your riding now.
Even if you only manage one 20 minute interval per trip you’ll still see results, but as was said, this type of training is most effective when combined with others, e.g. short intervals and short recoveries that target VO2max
njee20Free Member^^ this
This as well. I’m 67kg with FTP of about 280 (not actually tested for a while, and my PowerTap’s dead), and I’m not a hideous embarrassment.
dthom3ukFull MemberI’m using Trainer Road and its been a revelation for me.
You use your FTP to determine the intensity of the work outs. You choose a training plan and go from there. I’m currently five weeks into the MTB XC plan doing 3-3.5 hours a week on the low volume plan. I’m already feeling the benefits.
There are plans for just about every aspect of cycling.
butterbeanFree MemberThanks all.
Does Trainer Road give suggestions on the frequency of doing the interval sessions? I’m assuming I won’t be doing them every day (3 times a week maybe?)
mrblobbyFree MemberWith TrainerRoad you just pick a session from a large categorised library of workouts, or you can build your own workout. There are some plans on the website that you can follow if you like, but it doesn’t enforce this in any way.
mtbmattFree MemberAnything over 4 w/kg I’d say would be someone pretty fit.
Over 5 w/kg you can start mixing it with Elite racers and over 6 w/kg you will be looking at international level riders.FTP is just a number and doesn’t really mean too much. When you start training by power and have a curve, from CP5 (5 minute power) to CP120 (2 hour power) or even CP180 (3 hour) thats when you can see your strengths & weaknesses.
Your (anyones) FTP will hit a ceiling and for many people its impossible to get above it, without very focused training.
mayanFree MemberAlong similar lines, I have a question around heart rate and power and their correlation…
When you have the FTP value (both HR and watts), the aim is presumably then to train and you would then subsequently see an improvement in your power output.
As your heart rate range is essentially fixed (is this the case?), and your average heart rate you could ever maintain for the 20 minute test will be the same (give or take) and therefore training would increase the power output for a given heart rate – ie your efficiency.
If that’s right, then getting an FTP value for your HR is pointless…as it will always be the same?
So does that mean FTP Heart rate values are pointless without the power figures?
Or is average heart rate directly correlated to power output, and thus training will increase both together?
LSFree MemberThrow the heart monitor in the bin and just work with power, it makes life an awful lot easier 😀
mtbmattFree MemberFTP can never be linked to HR.
FTP – Functional Threshold Power.You can not have a “FTP HR”.
If you train by power, then HR can still be useful – but it becomes a secondary figure, usually used to check for things like over training or changes in fitness over a long period.
The-Swedish-ChefFree MemberThere is no real concept as an FTP HR value.
As you say, as you get fitter/more efficient you either get more power in your FTP test for the same HR value, or a lower average HR value for the same power output. (simplistic as training should increase your ability to work at a higher % of your max HR, therefore your average HR in an FTP would increase)
However as most people, inc. the OP do not have access to a power meter so using the average HR during an FTP test is a crude way to estimate what level of workload they should be aiming at for FTP/Sweet spot style training.
mattsFree MemberDon’t bin the HR!
It’s used to help monitor your stress response to training.
If you see a drop in HR for a given workout in the short term, it can be a good indicator that you are fatigued.
If you see a trend in HR drop for a given set of workouts (at a certain power) then it’s an indication of increased fitness. You probably need to increase your training load.
LSFree MemberYou can monitor your fatigue just as well with RPE. If you have a PM then HR just adds a layer of unpredictability that you really don’t need.
njee20Free MemberReally?
Not so sure about that. I wouldn’t try to ride to both metrics, but I’d not stop using HR just because you’ve got power.
LSFree MemberIt tells you how fast your heart beats. So what? You can infer some things from that information but as we all know, it’s subject to so many outside influences that to try and cross-reference with power in any meaningful way is a tricky exercise, and one which you may never achieve.
If you only have HR then fair enough, but when you’ve got something giving you a defined metric such as power then why bother?
rsvktmFull MemberWhen I first got a power meter I thought would look at HR after but not during, however i do now tend to use both to a degree dependant on what doing. I am about the same weight as op and produce a bit more power, but my aim in training has always been to produce power not lose weight. I just like sprinting..
As stated before if only got HR then spot on re sweetspot training using a known value, yes that may and will change but need to start somewhere. 7-10 hrs is plenty of time if used properly, commute is a perfect way to train. Most of my targeted training has been done during commute over the years as other riding is more social and fun.dirtyriderFree MemberCoggans reply here is good
http://forum.slowtwitch.com/cgi-bin/gforum.cgi?post=2830698#2830698
Rusty-ShacklefordFree MemberI’m 188cm, ~81kgs & my FTP was 239W, which gives a W/KG of 2.9.
Doesn’t seem too outrageous?It’s not.
I was about 81kg back in Feb and my first FTP test on TrainerRoad was 234w. I followed their 6 week SweetSpot Base plan and supplemented with additional workouts as and when when I felt like it; usually 1 or 2 extra per-week at lower intensity (so averaging 5 workouts / 5.5h total per week).
By April I’d dropped 6kg and my FTP was 305, so what your proposing is entirely do-able.
njee20Free MemberIs that using virtual power, or measured power, out of interest?
dirtyriderFree Member70w in 3 months? Off 5.5hrs – Nah, you got better at testing rather than such a big jump, which is generally where all the gains are
Like said above, climbing is more based on other aspects and not FTP mainly 5sec 1min and 5min
Chart your power profile
Rusty-ShacklefordFree MemberIs that using virtual power, or measured power, out of interest?
It’s virtual power using Arion Mag rollers set to resistance 1. I suspect my real/measured power will be somewhat lower but I’m happy that the readings are at least consistent enough for the purpose of improvement & progression.
Yeah, I think that’s bang-on, I’ve said the same myself in the TR thread. But then the same will apply to the OP…don’t you dare suggest they’re not ‘real’ gains!
mattsFree MemberJust another quick point in relation to the big increased in FTP over a short time.
The key thing to remember is that it’s *functional* threshold power. Not *theoretical* threshold power.
For someone who is either untrained, or unused to sustained efforts at race intensity, a large percentage of the gains over 6 weeks are learning how to push yourself. You were probably able to do 80% of the ‘gains’ the first time if only you knew you were.
uponthedownsFree Member239W to 300W is a big ask unless you are completely untrained and unfit.
As posters above have said you need a mix of longer threshold intervals e.g. 2 x 20min and shorter harder intervals above threshold. Mix it up and keep your body guessing. Also longer sweetspot sessions and don’t neglect endurance rides too. Try the Time Crunched Cyclist or TrainerRoad for plans. 7-10 hours structured training is more than enough to see a good improvement although 300W is asking a lot.
mrblobbyFree MemberAs has been said, it’s very easy to make big apparent gains in a short space of time if you are relatively unfit and untrained. When I started using TR I went from a 228 test to 305 in less than a year just following some of the set plans, but I’d say a lot of that was learning to pace and sustain an effort, and it was off the back of a year off through injury.
The hard part is where do you go once those initial quick gains are made 🙂
DT78Free Memberokay so I was lab tested in July, lots of interesting figures :
178cm / 74.6kg at the time / FTP was 265w 3.5w/kg/ relative vo2 max 65.4 / Max HR during test was 194 (202 in reality) / Max power 850w (ish not written down so forget true number but it was disappointing, however I was knackered at the end of all the tests)
By the end of Sept I was down to 72kg, PRing everywhere and starting to pick up low level (less than 200 rider contested) KOM’s on the road. Wasn’t retested so lets assume the power stayed similar (doubtful) so an increase to 3.7w/kg more likely close to 4.
That was training 8-16hrs per week for 2 months depending on work /life. Without a power meter.
No structured training plan, but a rough schedule of mixing long 5-7hr z2 rides (upto 100miler). Short hard 2 and 3 hr efforts (where I was trying to determine best HR to maintain, basically sweetspot training). And once a week 1hr banzai lunch time ride where I would attack all hills flat out and max the HR (basically interval training).
If it helps to put my numbers in relative terms in races like the Gorricks I get lapped by the likes of George Budd and tend to finish in the top third. So a long long way to go.
Starting out you’d want to do 2-3 interval sessions a week, 2 long base rides and some sweetspot training to get into the habit. Once you’ve got the habit a structured plan is a good idea. From there you can start with things like periodization (I’ve not done this yet).
I have found if I spend too much time on a structured plan, and in particular the turbo it sucks the life out of me and I start to become inconsistent with my training. Best to keep it fun, and the numbers should follow.
I do really want a power meter but cars and laptops keep needing replacing instead.
EDIT – diet wise I was following low carb diet zero dairy too. I came off this when I started dipping below 72kg as I was looking a little bit too skinny.
TiRedFull MemberThe big gains in fitness come early. Ability to sustain harder efforts is the mark of fitness – as is recovery. I would hope that with regular cycling, including pushing onto to harder efforts, the OP would see a reasonable increase in FTP before seeing reductions in bodyweight.
I started at 73 kilos and had an FTP of about 260 watts. Was barely competitive in 4th cat racing (dropped in fact). Regular riding (including 75-100 miles a week commuting), coupled with some longer riding and intense efforts (circuit races) have brought the weight down and the FTP up.
Two years later I’m 67 kg and and FTP of 290 watts (4.3 watts/kg). I can hold my own in an E123 race, can’t sprint to save my life (not enough watts or courage), and don’t have the skills to be really competitive on the muddy stuff (so race singlespeed 😉 ).
The OP will definitely see improvements with any form of regular riding. I think the most sensitive early measure will be speed of recovery after effort. Which is really interval training.
Kryton57Full MemberSame here. This year has been my first with trainer road, 2 sessions per week plus 1 hard 1 hour ride outside and 1 4hr club ride or Mtb at the weekend.
Feb to September saw a 20% gain in ftp and a 9kg weight loss. I finding the sessions much harder now though, and as I’m now just finished both sweet spot plans and about test before I start Novice Race next week, I am not anticipating many gains now – I do feel there’s a curve that flattens.
I shall be seeing TiRed to test it out on Feb 🙂
njee20Free Member70w in 3 months? Off 5.5hrs – Nah, you got better at testing rather than such a big jump, which is generally where all the gains are
Yeah, I think that’s bang-on, I’ve said the same myself in the TR thread. But then the same will apply to the OP…don’t you dare suggest they’re not ‘real’ gains![/quote]
That’s exactly why I asked, as I suspect that’s even more acute with VP. Not a bad thing, you’re still coming up with a more meaningful baseline!
dirtyriderFree MemberI am not anticipating many gains now – I do feel there’s a curve that flattens.
unless you up the hours?
mrblobbyFree MemberThere’s a lot you can do before you up the hours, most people tend to put in a lot of work on their strengths for example instead of working on their weaknesses as that’s generally harder and less fun. Some time just thinking about what you are doing can pay a lot of dividends. I guess it’s the training smarter thing. But yes, at some point you probably need to up the hours. By that point it’s diminishing returns though and you have to put in a lot of hard work for small gains (or even to just not lose what you’ve got.)
The topic ‘Did an FTP Test, what next?’ is closed to new replies.
