I serviced my hope v4 caliper a few weeks ago (done the job several times before) because the pistons were sticking and not retracting.
Since the service something is leaking oil and contaminating the rotor.
It definitely wasn’t leaking/contaminated prior to the service
I didn’t disconnect the hose so I don’t think that connection can be the issue.
I did the paper towel trick in the bled port and that is fastened up tight so I don’t think that can be the issue either
I did have difficulty getting one position back in after I replaced the seals so I wonder if I’ve damaged the new seal in the process?
Anyone got any tips on identifying the source of the leak/problem piston?
I’ve got another seal kit so I could just replace all 4 but I’d prefer just to do one if I can get away with it
James
