• This topic has 4 replies, 4 voices, and was last updated 3 years ago by jonk.
Viewing 5 posts - 1 through 5 (of 5 total)
  • Deore 11 speed cassette works loose!!
  • sheepshifter
    Lockring tight, no space for a spacer but the 3 largest cogs which are on a carrier work loose, help
    sillyoldman
    You’ve probably got a notched freehub which prevents the whole cluster being preloaded, or the 11T is on wrong which would also prevent the whole cluster being preloaded.
    Other possibility is that it’s a road 11 spd freehub like a Hope, and needs a spacer behind the cassette.
    cb200
    Yeah, I felt some play in my cassette last week. Tightening it did nothing. upon removal of the cassette, the freehub is notched big time.
    akira
    Sometimes light touch with a file might give it a bit more life.
    jonk
    If it is a hope (or any other) alloy freehub, check it for cracks – mine did this – the crack was tiny but caused what is happening to you
The topic ‘Deore 11 speed cassette works loose!!’ is closed to new replies.
