Defender 300tdi brake vacuum pump
Home Forum Chat Forum Defender 300tdi brake vacuum pump
Viewing 8 posts - 1 through 8 (of 8 total)
  • Defender 300tdi brake vacuum pump
  • Premier Icon keithd
    Subscriber
    Hi all, hoping one of the resident Landy experts can help with this. Just received a new pump to fit but am concerned as there is about 3mm of end float on the piston. DOES anyone know if this is normal? Cheers
    Premier Icon welshfarmer
    Subscriber
    What brand is the replacement. If AC Delco or Wabco I wouldn’t worry. If Britpart then I would.
    Premier Icon keithd
    Subscriber
    It’ s a Bearmach which I am led to believe are ok. Don’ know where it fits in the quality hierarchy!
    Premier Icon keithd
    Subscriber
    Welshfarmer, have you fitted one before? If so did you put no 1 cylinder to TDC or not?
    Subscriber
    Just above Britpart when it comes to moving parts and getting worse. Simple rule of thumb is that is if has moving parts, precision surfaces, is part of the safety system, or seals something then buy genuine or OEM quality. Britpart/Bearmach etc are probably OKish for mudflaps and seat covers.
    Subscriber
    I have fitted them in the past but it is 5 years ago at least so I cannot recall the process without looking it up sorry.
    Subscriber
    Have a read of this thread. It may help. There is a bit about TDC as well
    <span style=”font-size: 12.8px;”>https://forums.lr4x4.com/topic/56096-vacuum-pump-oil-leak/</span&gt;
    Premier Icon keithd
    Subscriber
    Cheers for that. Will check it out.
