Home Forums Bike Forum Dart 2 Forks, Post mount to IS for Magura Julie? confused
Viewing 4 posts - 1 through 4 (of 4 total)
  • Dart 2 Forks, Post mount to IS for Magura Julie? confused
  • brungle
    Hi guys,
    building a bike for mate from old bits. Thought I had everything sorted then realised the Magura Julie front disc caliper (IS fitting) wont fit the Dart 2 forks, I’ve purchased an adapter but the caliper position wont align with the disc location..
    its a 160mm Shimano centre lock disc. have I installed that wrong?
    pics below as its hard to explain..
    basically can someone explain what type of adapter I need please?
    I have a spare 203mm rotot and post mount extension adapter if that will help..
    brungle
    do I need something like this ?
    thanks
    coatesy
    Yes, you’ll need something like that Hope HBSM20 mount, but if the caliper was previously running a 160mm rotor on the front then you’ll need a 20mm bigger rotor.
    brungle
    thanks for info
The topic ‘Dart 2 Forks, Post mount to IS for Magura Julie? confused’ is closed to new replies.
