Chains have been filthy over winter so last night was spring clean time
Fenwicks stuff is good in the whirly Park chain cleaner thinghy. Probably all that’s ever needed however was feeling the need for a full deep clean….
For a real deep clean prior to relubing with Fenwicks Stealth I soaked the “nice” bikes chain in a jam jar of petrol (yes I know…). Very very dry after drying off – hope the Stealth lube is as good as it claims to be!
The commuter bike was cleaned tonight – after the whirly Park cleaner treatment I tried out Paraffin for the jam jar soak. Leaving it to dry overnight and will see how the Stealth lube takes tomorrow.
FWIW – when I commuted across the south downs daily a few years ago I got through chains every few months. I tried regular complete degrease and lube, no degrease but add more lube regularly and also just fit and forget – let factory grease do its thing. They all lasted the same so I switched to cheap chains didnt bother lubing (other than a wipe down) and changed regularly – was cheaper. Even more so on SS when chains were £8 each.
