So i have a kinesis sync ht frame that has a pf30 bb shell that is 73mm
I wanted to reuse a chainset that is ht2 with a 24mm spindle
I tried getting two cheap pf30 to ht2 thread converters and fitting the old ht2 bb and chainset
After a couple of rides the bb converter worked out of the frame, loosened the crank arm and popped off and lost the plastic preload bolt.
I found a thread that mentions crank loosening being caused by not enough clamp surface on the spindle… caused by the 73mm bb only needing 1x 5mm spacer drive side.
So i went and spent £60 on a wheels manufacturing pf30 to ht2 bb as it would thread together and hopefully hold.
My question is, will the spindle have enough clamp area as the wheels manufacuturing bb has given me more clamp area on the spindle but there is still 5mmish of space of threaded crank arm clear of the spindle?
Anyone else running ht2 cranks in a 73mm pf30 bb, and if so what did u use?
