Most roadies look miserable because they are miserable because road riding is miserable.
Aluminium is the best frame material if you are after a balance of strength, light weight and affordability.
Torx head bolts have no place on a bike and are just the industry making things more difficult for the casual home mechanic.
Most SRAM components have at least two sub-components too many.
Expensive saddles are ridiculous.
Tread pattern, compound and carcass weight are all secondary to how easy the tyre is to get on and off the rim with cold hands.
Expensive waterproof jackets are pointless. They stay waterproof for about five minutes longer than cheaper thinner outer shells and the abrasion from pack straps and general gritty cack ruins them just the same. Under layers plus a cheap outer is best.
You don’t need ten thousand lumens of trail-melting light to have a perfectly good light set up for night riding.
Strava will soon start causing no end of bother with cheeky riding and access issues.
