regardless of the issue is there any potential comeback if i was involved in an accident for example?
Only if it could be shown that the engine management issue had contributed to the accident, which seems pretty unlikely.
There could be any number of faults that could be causing an engine management light – a lot of them won’t have any effect on drivability – things like stuck swirl flaps, crank position sensors, lambda sensors etc. Other potential faults like a bad coil pack or faulty turbo you would definitely notice but they aren’t going to make you more likely to have an accident.
Unless you drive around staring at the engine management light instead of the road!
