are you talking 7g for a double?
No, sorry, ijumped back and forth between singles and doubles without really making that obvious. The ‘rules’ for making an espresso, from the national espresso institute in Italy specify:
Necessary portion of ground coffee 7 g ± 0,5
• Exit temperature of water from the unit 88°C ± 2°C
• Temperature of the drink in the cup 67°C ± 3°C
• Entry water pressure 9 bar ± 1
• Percolation time 25 seconds ± 2,5 seconds
• Viscosity at 45°C > 1,5 mPa s
• Total fat > 2 mg/ml
• Caffeine < 100 mg/cup
• Millilitres in the cup (including foam) 25 ml ± 2,5
Or 14g for a 50ml double. If you don’t know this you probably have never had ‘proper espresso.😉 First time I had one was a revelation. Taste nothing like the espresso most places serve. It’s buttery and Rich and nutty and not particularly acidic.
Too many places overdose, which means roasters make roasts and blends that need overdosing, which leads to overdosing which leads to etc. etc. Also a lot of places think fresh coffee is best. Seems like 2 day old or more is better.
