Pretty sure this will be the same issue it had last year Tony?
I suspect you’ve got a dodgy O ring somewhere in the fuel system, allowing the High Pressure pump to pull in air (pretty sure it’s hasn’t got a lift pump, as it has the rubber “hand” bleeding bulb on the fuel line from the tank)
You could lash up a “gravity fed” fuel feed, direct to the HP pump, using something like an plastic coke bottle etc. Hang this a few feet above the engine (off the bonnet catch with the bonnet off??) You’ll have to jury rig that to the HP pump fuel feed pipe, probably try to uncouple the feed line just in front of the rubber bulb?
In effect, any leak will now be outwards rather than inwards, as you have exchanged suction for pressure. If this gets it to start and run, then the next issue is finding the leak, which could be anywhere in the fuel system, and even in the HP pump itself ;-(
