I have a really old Chromebook, its over 5 years old and is basically a glorified web browser, it cannot install apps like the newer models.
Its amazing…does everything I originally needed, the only reason I still have a PC is that I wanted to do basic photo correction, and edit video. I bought a fairly expensive laptop last year and the Chromebook is so much more satisfy to use with its total lack of annoying popups, prompts, invasive software updates and bongs, chimes.
The battery life used to do 2-3 days of fairly heavy use and still gives the windoze laptop a run for its money, and it is as quick as the day I had it, which you can’t say for any budget windows laptop which will be dead on its feet after a couple of years.
Google knows all about you anyway unless you make a special effort to avoid android, youtube, facebook, whatapp and all that, its no different.
My laptop will eventually die but it will be the budget case that gives up, the case is cracked, screen bezel puckered up and one hinge is reconstructed using a bar, araldite, some pvc tubing, metal P clip and a nut and bolt straight through the screen bezel.
