@Harry_the_Spider no it’s the one at Bournemouth Aviation Museum fantastic little place. A lot of sawn off cockpits as well as a few whole planes but the kids can sit in most of them.
I *may* have sat in the Lightning cockpit myself. 😉
@freester. I see from BM that you are starting your Sea Vixen too.
Mine is the Cyber Hobby version. Instructions don’t say it, but the nose ballast is 25g apparently. I’m going for fishing weights and PVA as I’ve bought a resin nose cone that is solid, so I can’t fill it with liquid gravity. I’ll try an get a tyre balance weight in too if I can get it under the cockpit floor.
Also, the seats are way under sized, so I’ve gone with some Pavla resin ones that were about £3 each inc postage.
Been waiting for years to build this, but every time I’ve opened the box I’ve been daunted by the superb quality of the mouldings and the risk of buggering it up!
Yeh I’m doing the 1/72 Revell Sea Vixen. It’s my son’s. I know a lot of people say the nose doesn’t look right but as far as we’re concerned it resembles a Sea Vixen.
I want him to do as much as possible so will have to suppress my inner perfectionist. The instructions say 25g of weight. I got some liquid gravity from my local hobby shop.
Followed. I’m doing the Revell kit with my son. I’m gonna do it straight out of the box but I have ordered some decals because my son wants it to be XP924 the last flying Sea Vixen (before her belly landing 🙁 ).
I’m going to have potentially 4 models on the go. I’ve got a little 1/72 Thunderbolt I’m doing with my son. Fuselage assembled doing the painting.
Early stages of painting Sea Vixen parts before assembly.
Ditto for a 1/72 Hobby Boss Tomcat.
Then an Academy 1/72 F/A-18 arrived yesterday I’m going to do the Britmodeller group build. It’ll be OOB. I suspect the Tomcat will have to take a back seat.
Well me and Jr been making slow but steady progress on his Revell Sea Vixen
Mostly his work I helped a bit with the masking tape belts. It’s not up to the standard and detail on Britmodeller but it’s better than painting them on.
And our first mod out of the box… He wanted it to be ‘Foxy Lady’ so I got some decals off the dreaded bay…
Hmm, I think I decided I’d share Warhammer things when they involved some converting or other modelling effort, didn’t I? So here’s a stupid little Imperial Guard light tank that I converted out of a larger Imperial Guard IFV and a spare turret. It is supposed to be as illogically impractical as other Warhammer 40,000 tanks.
The finished piece:
A WIP shot that helps show which bits were scratch built (white plasticard) and which bits were taken from actual kits, with or without some conversion effort:
What this thread needs though is a Big Jug! P47D Razorback in 1/32 to be precise…!
It has taken a loooong time to get to this stage, due to many other commitments. It’s quite an involved build and lots of dry fitting and test fitting is recommended and you need to be patient. A lot of the parts can be problematic if the stuff you’ve done 2 or 3 steps ago isn’t just so. Fitting the interior into the fuselage will be a major test of that.
Bizarrely the kit includes a clear engine cowling to show off the yet you be built engine. Even more bizarrely I am leaning towards keeping it clear, just because I’ve never seen it done. There is quite a nicely rendered piece of nose art on a decal, and I think it might look interesting to put that on the clear cowl, varnished over. We will see. I have seen some warnings that the cowl does not fit over the engine in any event so it may have to be painted anyway.
Thanks guys. 🙂 There’s quite a lot of snobbery about dry brushing but I think it produces quite a nice worn look on stuff like my tank and I’m prepared for things to look not quite perfect in return for the time savings that dry brushing can provide compared to manually highlighting things!
That Thunderbolt cockpit looks impressive (and large)! I’ve got a 1/32 Tamiya Phantom kit that has clear radome parts, I have wondered at times whether I could use an airbrush to paint most of the radome but have one clear bit allowing the interior detail to be visible and manage a nice fade between the painted and clear bits.
Coming together. The fit is absolutely superb, but I’ll have to leave it now so that the booms don’t droop and skew the tail.
@freester look out for blind holes in the underside of the wings. Maybe the Revell instructions are better than the Cyber Hobby, but I missed one as there is an extra one on the starboard side.
@Harry_the_spider I’ve just looked at your pics again. Yours looks like an FAW1 the booms on the top of the wings don’t look big enough they should extend over the front of the wings for an FAW2?!
@freester – There QC should have picked that up, that’s a short in the moulding, not enough plastic has been injected to bridge the gap at that point, or plastic not hot enough, I’m assuming the tail fins should be symmetrical as well but they’re not.
Get it back to Revell, I’d be expecting a new kit!
@Freester again. The FAW2 kit was an upgrade on the FAW1n (as in real life), I’m sticking the extended booms on tomorrow. They are on another spru. I’d got the tail assembly square and was waiting for it to set.
I’m off to the shops again as I’ve found out that the wheel wells and the door interiors are a greeny/bluey/grey that I don’t fancy having to mix a couple of times, so I’ll see what Tamiya and UKIP Jim at the LMS have to offer.
Well its finished bar a couple of small bits and maybe some weathering but to be honest I’ve lost interest in it now! Its a really nice kit but my attention to detail just doesn’t do it justice.
@Harry_the_Spider – nothing from Jadlam but I also sent an email to Revell service and they have replied already asking for an address to send replacement parts.
Wasn’t sure whether to post these or not. My 1/72 P47 has turned into a bit of a mule. Challenging blue camo, and a metallic underside.
All hand brushed using Revell enamels. Thinned with Humbrol Thinners. I masked the metallic painted a few coats of black and then 4 or 5 coats of Revell Aluminium 99. I’m kinda happy with the metallic finish and the edge / masking. The dark blue camo looks I’ve done it with a felt tip pen. Some paints go on so well, look so nice. Others are just frustrating!
Posted 2 years ago
Viewing 40 posts - 1,761 through 1,800 (of 2,328 total)
