What scale is the Lightning?
1/72
I think you’ve overdone the panel wash on the Lightning Jon to the point where it looks like a cartoon of a Lightning. Also you’ve applied the decals over the top of the panel wash.
A little harsh, but arguably fair. I think its down to a combination of things.
Firstly – decals very much underneath the panel wash and in the plastic, its pretty obvious on the sharkmouths However the XS903 decals really didn’t want to soften into the panel lines despite copious Microsol.
I think I went a bit OTT with the “clarity” slider in Lightroom – it makes the plane “pop” from the background, but does emphasise the dark sharp edges.
Then there’s the combination of hefty Airfix panel trenches and Flory washes. I did consider not doing any weathering, but pics of the real XS903 look pretty grubby around the belly and backend – and as soon as you end up putting a wash on, you’re kinda stuck with whatever ends up in the crevices – unless someone can suggest a method for reducing the effect there without washing it off elsewhere? It’s definitely an issue on that PR Spit, which really does look toylike. The relatively pale colouring also makes it contrast more.
