Home Forums Bike Forum Cheaper version of Surly Monkey Nuts?`
Viewing 7 posts - 1 through 7 (of 7 total)
  • Cheaper version of Surly Monkey Nuts?`
  • dufresneorama
    Looking for monkey nuts, or something a bit cheaper to for my slotdrop inbred. the front mech clamp fouls the rear tyre.
    Anything out there?
    dufresneorama
    Seen these online…worth a bosh?
    scaredypants
    If your dropout slots open backwards, i reckon you could probably bodge a chainring bolt in there. Are chaintugs no use ?
    If they open forwards, dunno – can you get chaintugs that work “round” the cowl ?
    dufresneorama
    They open backwards. I think chaintugs would work, wouldn’t it mean more faff taking wheel out though?
    Also seen these: Planet X exocet dropout spacer but doesn’t look like there would be anyway of attaching them so they didn’t fall out when removing the wheel.
    I’ve got a load of chainring bolts in the shed, so maybe worth a shot.
    scaredypants
    I assume you’re using gears ? (otherwise a chaintug would be much better)
    I had (one) on-one chaintug that looped round the axle of my QR hub. WHen I undid the QR and released the chain from the sprocket, the wheel pulled out backwards and the tug stayed hooped round the axle. Was a tiny bit more fiddly to put back in, but still easy
    dufresneorama
    Yeah, will be running this one geared.
    Thanks for the reply, I’ll give the chainring bolt a go as hoping to finish build tomorrow. It should provide just enough space to miss the front mech.
    Thought about using an e-type front mech (fiver for the LX one on chainreaction) but i’m running a 48t front ring and I doubt it’ll cope.
    singlespeedstu
    I think I have a brand new pair of monkey nuts in the garage you can have for the right price.
    Drop us an email if you’re interested.
The topic ‘Cheaper version of Surly Monkey Nuts?`’ is closed to new replies.
