although the bracket isn’t great.
For some reason can’t remember I have two different style brackets for mine. The one with a thumbwheel-tighten, and one with just an allen-bolt (below)
This clamp is the better of the two, IME. In my experiments with either one success seems almost entirely dependent on installing the shiny black rubber strip correctly inside of the clamp. I manage a good solid grip on the bar, but agree the bracket itself could be better (and directional)
Ended up mounting the thumbscrew clamp on a fork-crown bracket. It works but find that I need to retighten from time to time when the ambient temperature changes drastically 🥶🥵
I thought about changing it to an Exposure bracket by bodging an Exposure cleat on to the underside of the unit. It’s easy to remove the stock cleat from the PR series (two small allen screws iirc) so don’t see it being too much of a major DIY to fit an alternative of choice? Warranty-voiding tho it may be.
For road and light gravel it seems functional as supplied tho, tbh. I’ve used much worse.
