Are you on the debonair spring or solo air? I’ve got the lyrik ultimates with the same damper and the debonair spring. Weigh 12st and ride fairly aggressive. Running 30% sag (more that I did on my old forks but these seem to work better with more sag as the mid stroke of the debonair spring is so supportive). I have both HSC & LSC wound all the way off & find them plenty supportive and insanely smooth. Usual trails are Peak & lake District rocks and steep, rooty off piste stuff but I also found them fine with all the compression wound off at BPW, revs and black mountains too. I was fully expecting to have to wind a load of compression on to deal with hitting berms and jumps but they held up just fine. There is still a reasonable amount of HSC present with the dial wound all the way out. Only time I’ve felt like I wanted more LSC is stood up climbing. I borrowed a shock wiz and it confirmed that the setup was good, it did tell me to run less rebound damping than I used to, they felt super bouncy pushing down on the bars but so much better on the trail. First ride, run em wide open, don’t choke the spring with excessive compression damping and start adding clicks of LSC if you find them too wallowy. I think you’ll be pleasantly surprised, it’s an amazing damper!
