- This topic has 60 replies, 45 voices, and was last updated 2 months ago by PrinceJohn.
Car park bike stand
Get the butler to hold it?
Posted 2 months agoTo be fair to the OP I won’t lean my bike against the car either, I always used to and once it was leaning against my shiny new E Class for about 10 mins before it decided to slip and crack the lens on my rear LED lamp cluster. Not ideal.
I’m cheaper than the OP though, so I solved it be leaving my bike on the floor now seeing as that’s where it’s going to end up anyway.
Posted 2 months ago
I’m not fussed about it getting run over either. I figure they’ll be buying me a new one if that happensI’m assuming that the OP uses a towbar rack, because:
1 He wouldn’t put it in the car if he’s worried about the rear tyre leaning against the car
2 It’s an eBike and too heavu for the roof.So why not just lean it against the towbar rack?
Posted 2 months agoI normally lean mine against a nearby T5
Posted 2 months agoHow about a gripster? Nice and small. Pop onto handlebars, lean that against car, no damage done. Used it inside the van i used when i went up north with the bike
Posted 2 months agoHow about a couple of pieces of old towel?
A piece about 6″ square is plenty big enough to act as a pad between handlebar/seat and paintwork.
Virtually free, small and easy to carry, almost weightless.
Alternatively, put one of your riding *gloves over the bar end before leaning it against the vehicle.
*Socks also work but are much less convenient as you have to put your sock and shoe back on whilst holding your bike away from the car in a potentially wet and muddy carpark. You can probably get a friend to hold your bike whilst re-socking and shoeing if balance is an issue.
Posted 2 months agoI can understand having a stand for carpark fettling. I can just about understand the OP.Leaving a bike away from cars maybe mean it is out of sight slightly. Maybe it’s not such a bad idea.
Posted 2 months agoIf you won’t use any old stick, find a stick you like the look of (maybe a Y shape), whittle it until it feels like it’s special and yours. Maybe even carve your initials into it and give it a name like the StickStand and sell it on ebay and make millions so you can just but a new bike each time you ride and not worry about it getting run over.
Posted 2 months agoReverse the car in to the bay, leave bike behind car?
Posted 2 months agoI’m not fussed about it getting run over either. I figure they’ll be buying me a new one if that happens
Aye, best of luck with that.
Posted 2 months agoIf you see a silver Nissan Pathfinder with a dented boot lid in the car park your welcome to lean your bike against it😊😊
Posted 2 months agoWhat about a folding walking stick – perhaps with a modification to the handle to make a ‘Y’ shape??
Aren’t you worried you might for forget which one?
Posted 2 months agoI have something similar to this;
https://www.tredz.co.uk/.Minoura-DS-40CS-Chain-Stay-Bike-Stand_114534.htm
Folds flat so takes up very little space and allows the rear wheel to rotate for cleaning.
Posted 2 months agoHelicopter tape the car area for leaning duties. Might only be a small patch.
Posted 2 months ago
Or trap a big towel in the door.Never had this problem? I did run over someones kiteboard in a car park once…. I put that down to the idiocy of the owner though.
Posted 2 months agoHandlebar Jack
Posted 2 months agoCan you tow another car that you can then lean your bike against worry free?
Posted 2 months agoJust lean it against the car parked next to you
Posted 2 months agoWhere is this carpark where bikes get run over? I need a new bike…
Take two bikes and lean them against each other. On the plus side this gives the help transportation to get them home without messing up your car interior.
Posted 2 months agoThe invisible stand?
Posted 2 months ago
