Got an L200 that sounds like the engine is trying to escape through the bonnet. It’s the newer shape 2006-onwards model.
2.5 diesel, auto gearbox.
Had a problem where it wouldn’t start at all so has been in the local garage for about 3 months. Turned out to be some kind of pressure hose/switch thing but it took a lot of trial and error.
Apart from the noise it now runs the best it ever has. Fuel economy up, more “poke”, it just sounds awful. Really rattly, seemingly coming from rear of engine, I’d probably say top end rather than bottom but it really is too loud to pinpoint. The noise disappears completely from around 2000rpm if you rev it in neutral. If the engine’s under load (i.e. when driving) the noise remains, although it does get better the higher the rpm. If you’re driving along maintaining speed and find the sweet spot where there’s very little load on the engine the noise disappears, but comes back if you either press the accelerator or take your foot off and start coasting. The local garage is flummoxed, because apart from the noise it’s great.
Can STW’s resident experts think what might possibly be the cause?
