Or are they just bent?
The rings are not running straight, by about 3mm between 12 and 6 o clock. I noticed this as rubbing on the mech cage after a recent strip and clean, haven’t crashed or dropped the bike.
If I swap the cranks to another bike, the problem travels with the cranks. Likewise if I put different cranks on (using same cups), they run true.
Strange part is that if I fit just the DS crank, it runs true. Fit the NDS with the centre bolt (Hirth joint) finger tight, still true. Torque the bolt, and they go out of true. So I’m not sure they are simply bent. Have cleaned the teeth of the Hirth joint, fitted new bearings and tried different cups, but no better.
They are Chorus cranks, about a year old or so. Back to the shop with them , or have I missed something?
