hiya, I have a set of rods I’ll take a look at those magnets sounds like the business.
yes very small hole where the light fitting is, and the entry feed is via an adjacent room but through an external wall and cavity. I believe the switch and fan cables are likely chased in under the tiles and which is a right pain so I just plan to disconnect and move the position whilst I’m at it. (who puts a switch for a bathroom in a cupboard outside it??)
so plan is relatively big hole in cavity wall under floor parallel to existing feed to run the switch live in to the light hoping I can fish it through. it’s only a couple of metres tops.
likelihood it’ll take me all day and I’ll loose some rods, very high!
If I make an access hole in the ceiling what the best approach? something like a 75mm holesaw and then make good with a ply/plasterboard circle glued back and filled?
