Laminate, vinyl or engineered wood with underfloor heating? What’ve you guys used? Would this one be any good?
We’ve got an outbuilding with a concrete floor with wood-look vinyl flooring fitted, quite a springy one, works well. No worries about pools of sweat etc, easy to clean, stick a trainer mat under the turbo to reduce noise further.
You don’t need underfloor heating with a turbo ime, but if you want to use it as a gym as well, I’d have some sort of heater in there. You might even think about a dehumidifer to minimise condensation. As above, a big fan is a very good idea, preferably several of the things.
I’d also look at a rocker plate for the turbo, it makes it feel a lot more natural, reduces saddle soreness and reduces the load on carbon chainstays/seatstays.
