I had a new oil tank installed recently. It sits on slabs, on sand, on the piss. It’s sloped front to back away from the pick up so even when 1/3rd full, it thinks it’s nearly empty.
I plan to jack up the low end and possibly use self levelling compound or a very wet concrete mix to flow under the resulting gap, obviously shuttering off the edges etc to stop everything escaping.
Is this the simplest way? I dont want to move it and re-lay the slabs again. It weighs ~500kg, has 500L of fuel in it and getting the div back who did the job is not an option.
Does this make sense and any other options that are easier/cheaper/quickerer please?
