If it’s an orangery with a solid/mainly solid roof it’s going to need a Building Regs application and will be classed as a highly glazed extension, which will need to comply with Part L. It will also need to comply in all other respects. A good (brief) guide for Part L HERE
I know the trend is to remove doors and have on open space, but seriously consider keeping doors in, or having new doors that work more flexibly. Generally, if you retain or install external grade doors between the dwelling and extension, and zone control the heating in it, you need not demonstrate compliance by any of the long winded methods above, just elementally with respective ‘U’ values. Regs aside, conservatories and highly glazed extensions with no effective thermal separation DO act as huge heat sinks, DO get cold and could make the rest of the house cold or dramatically increase your fuel usage.
Triple glazing is expensive, and suspended timber floors are outdated/rarely seen these days, for some good reasons, though they’re not terrible. Get the design and complete approach sorted before you focus on specifics.
