I have a constant squeal on my BB5 caliper. Mostly when brakes are not applied. It’s been the same with the past 3 sets of pads. I’ve tried a different disc and I’ve tried aligning the caliper but it’s just getting worse.
It’s been well used now and done a good few thousand miles. It never used to do it so I’m wondering if it’s some kind of wear in the caliper or something else.
You can physically see the shimmy in the pads and the vibration transferred through the chain stay.
Could it be as simple as adding some copper grease to the back of the pads like you might do with a car, or is there anything else I should look at before giving in and buying a new caliper? Bit fed up with it now.
