• This topic has 5 replies, 5 voices, and was last updated 1 month ago by pdw.
Viewing 6 posts - 1 through 6 (of 6 total)
  • Brake pad compatability…. 105 & Tiagra
  • alpin
    Want to stock up on some pads. Do 105 and Tiagra use the same pads?
    Hydraulic discs.
    simondbarnes
    Yes
    alpin
    Woohoo!
    Cheers!
    chaos
    Yep, and Ultegra/XTR/DuraAce as well!
    There is the Shimano compatibility chart although it only shows the latest iteration of brake pads.  The numbers (03,04,05) are just the generation of pad material so a G03A will fit the same as a G05A but the latter is supposedly improved and lasts longer.
    https://productinfo.shimano.com/#/com?cid=C-460&acid=C-653
    The Gorilla website, as an example, also shows compatibility of their equivalents.
    https://gorillabrakes.com/products/shimano-105-hydraulic-disc-brake-pads-br-7070-l03a-l02a?variant=45281647165759
    FOG
    This has been very useful for me as I was scratching my head about which pads to buy for my Tiagra.
    One question though, what do the different initial letters mean? Some have a KO prefix and some LO. Is it basically the same pad but with the fin, or is it something else?
    pdw
    Yep, I think so.  K = no fin, L = with fin.  As above, the number is the generation, and the letter at the end is the material.
    G and J are the not finned/finned equivalents for non-flat-mount brakes.
    K and G look quite similar, but are not interchangeable.  Likewise L and J.
