So i’m working my way round the new ‘old’ house and have a slight problem with the floor joists downstairs.
I removed a (decorative) brick fireplace and it looks like the support pillars under the floor joists have dropped a little at some point so now there is about 1/2 inch of bounce – i guess the weight of the fireplace was hiding this and they have risen up now it’s gone.
I am thinking it will be fine to just jack up the joists (assuming they are in good nick) and add a wedge on top of the original brick pillars to remove the gap.
I am hoping this has happened over a long period of time (house is 1930) in which case further movement should be mininal….
Or should i call in the professionals for a more detailed survey / investigation of the problem!?
Would appreciate any suggestions?
