Viewing 3 posts - 1 through 3 (of 3 total)
  • Bottom Bracket spacer help needed
  • trailwagger
    As in previous thread I was looking at options for a new crankset to swap to for a 36t option for a loaded bike.
    I saw this raceface crank for next to nothing
    https://www.wiggle.co.uk/race-face-ride-narrowwide-single-ring-chainset?sku=5360612639
    My bottom bracket is ultegra hollow tech two. And the frame is 68mm.
    First off have I bought the wrong crank?
    Adding it’s the right one then I guess I need some spacers?
    Anyone able to point me to the right ones and how many do I need?
    Thanks.
    dhrider
    The ultegra BB cups are slightly narrower than the MTB equivalent so you’ll ideally need a MTB bottom bracket. (or fill the gap with axle spacers)
    Any hollow tech II MTB bottom bracket will work and you put 2 spacers on the driveside, 1 on the non driveside for 68mm.
    Only caveat here is your frame may be made for road cranksets if a ultegra BB was fitted so your chainline may be way out with a MTB crankset / BB.
    trailwagger
    Mmmmm. Ok. Can the chainline be corrected by putting the spacers on the non drive side?
    It’s a grx 1x setup if that makes a difference.
The topic ‘Bottom Bracket spacer help needed’ is closed to new replies.
