On the wheel if you have Hope hubs you should be able to get an adapter. If you don’t you might find you could get something from MRP or Wolftooth dependant on hub.
I love my gx 11 speed setup – on the fa I use a 30t chainring – on the ht I use a 32t.
I suspect your crank might not take smaller than a 32t so going Shimano/ Sunrace would give you a lower gear on the cassette in 11 speed (sram biggest cog on 11 speed is 42).
I’d just try your cranks and see if they clear – it doesn’t seem to be an exact science. I’ve got a boost rear on my Vitus, with direct mount cranks with boost chainring (32t) and it’s got the tiniest clearance between chainring and chainstay. I’d be more comfortable if it was just a little bit further away.
