Viewing 6 posts - 1 through 6 (of 6 total)
  • Boost hub back to non boost standard…possible?
  • panzerjager
    Is it possible to convert a DT Swiss boost 110mm hub back to 100mm with a change of endcaps, or are they physically wider bodies?
    Google isn’t getting me a definitive answer.
    Thanks.
    simondbarnes
    No
    greeny30
    No, you can’t take anything off the disc side so you’d need to remove 10mm off the drive side endcap.
    dc1988
    Superstar hubs are the same for boost or non boost, you just need different end caps and a re dish to switch. I don’t know if this is the case with dt Swiss but it isn’t unheard of.
    Superficial
    No, with DT the hub shells are different Boost to non Boost.
    panzerjager
    Ok, thanks everybody, unfortunately, that’s as I suspected.
The topic ‘Boost hub back to non boost standard…possible?’ is closed to new replies.
Thanks for popping by - why not stay a while?IT'S FREE
Sign up as a Singletrack Member and you can leave comments on stories, use the classified ads, and post in our forums, do quizzes and more.
Join us, join in, it’s free, and fun.
