They measure the electrical resistance through your body (scales do it through tour feet/legs), water conduicts better than fat, so based on that they can figure out how much fat there is.
Some others work on the same principal but you hold onto a device so it uses hands/arms. Others use all 4, (some of) those can even tell you the imbalance of muscle between left and right*!
There are others like DEXA scanners which x-ray your body and estimate based on that. Others measure your volume by sitting in a pod and altering the air pressure slightly, then compare that to your weight. Or callipers to ‘pinch’ the fat at various points on the body. The dunking in a pool method’s gone out of fassion for being uncomfortable 9you need to competely empty your lungs for an accurate reading), and being time/space consuming.
*I broke my left arm last year, that’s my excuse and I’m sticking with it!
Well i just measured 1.8Mohms across my feet with dry feet, and 0.2Mohms with wet feet. So, i’m either all muscle or all fat, one of the two.
all wet feet does is improve the contact between the pin on the multimeter and your body, the bigger pads on scales do a better job. Do you think a fraction of a mm of water on the sole of your feet makes more or less difference than about 2m of feet/legs/hips (which are also mostly water) that it also has to measure?
