Home Forums Chat Forum BMW question
Viewing 9 posts - 1 through 9 (of 9 total)
  • BMW question
  • garage-dweller
    I’m on the hunt for a new (to me) estate car.
    5 series or 3 series is on the possibles list of the early Euro6 vintage (ULEZ proofing) so 2014-2017 ISH.
    A lot of the obligatory dashboard pictures show a small yellow triangle with an exclamation mark in it just by the 0 on the speedometer or in the bottom centre of the dash.
    It’s not the handbrake. That’s a red symbol more centrally and my Google skills are failing me on this one light.
    Anyone know what it is?
    If it’s a “needs fixing” item then it’ll save me wasting time looking at these cars with any more scrutiny.
    doomanic
    This one?
    doomanic
    Or this one?
    1
    Kryton57
    FFS Dominic, this thread could have run for ages, but you ruined it on the first post 😀
    Joust for the OP, its an “alert” and the Check Control above will tell you, but I suspect the reason its so common is the fact the car is flagging for an past MOT due date, service due date, low fuel or some other “sitting on a forecourt” related issue.   Just have a check first.
    1
    unsponsored
    The triangle/exclamation light is a generic warning.  Comes up when fuel hits low, washers low, bulb gone etc.  More detail pops up via idrive. I have a 2018 F31.  Same on the mini and 1 series I had.
    garage-dweller
    @doomanic thanks it was the top one. It just didn’t appear on the other lists I found.    👍
    @unsponsored
    thanks – low fuel could be it for a number of them given they are on forecourts/up for sale.
    Pretty much every ad I look at the thing is lit up but actually may not be a major cause for concern given the low fuel levels of a lot of them.
    1
    TheGingerOne
    I would expect in the vast majority of cases it is low fuel rather than anything actually wrong
    garage-dweller
    😂 Well I’m grateful at least.  I’m torturing myself enough with the EClass/5series/V70 or just give up and buy a newer Skoda instead without a whole thread of doubt and uncertainty.
    1
    fs1e
    It’s a warning light that comes on for all sorts of things on my 5 series including telling me that the rear seats have been folded down! A message comes up to provide more information. An engine management light on the right hand side of the instrument cluster warns about engine related issues
