Evening stw tech heads..
I’ve got a narrow wide 34t chainring on a hack bike that I’ve built and it’s now specced with a 9 speed sunrace casstte.
It’s a 9 speed chain.
When I put it in largest sprocket (1st gear) the chain drops off of the narrow wide chainring as you pedal.
It looks to me like it is peeling off the top almost like when you shift with a front mech on a double set up. Happens on smooth ground and you can see it happen as you pedal slowly
Is this the chain line plus 9 speed chain in the narrow wide chainring causing this?
Would a 10 speed chain maybe help? Can you eveb use a 10 speed chain with a 9 speed block?
