I was given a One Up EDC pump as a birthday prezzie and apart from housing one of their mini-tools and other EDC options, it works really well as a pump too. A little heavy and expensive, but seems bombproof and doesn’t screw on.
That said, I also use a Lezyne pump and use one of the little Park Tool valve core tools to nip up valve cores good and tight after which the Lezyne pump works fine. Ironically the only issue I’ve had with the Lezyne, is the air bleed valve in the hose leaking after somthing gritty jammed the valve slightly open, fixed by stripping out and cleaning, but a pain in the backside when you’re 25km from home with a flat 🙁
