• This topic has 21 replies, 16 voices, and was last updated 1 year ago by tdog.
Viewing 22 posts - 1 through 22 (of 22 total)
  • Best hydration packs/bladders?
  • jayx2a
    Member
    Currenlty got an Evoc Stage 6L and although the bag for the most part is ok, I find the bladder a bit average.
    Its giving off bad flavour, the seal leaks a little and the mouth piece is not the easiest to use.
    So either thinking of a new bladder or new pack entirely.
    Anyone got any bladder recommendations? Need to have a central hoop at the top and probably still need to be 2L, although 2.5L might work.
    If not – what bags are everyone running?
    Premier Icon rossburton
    Subscriber
    Osprey bags are pretty epic and their bladders are available on their own.
    Premier Icon jimdubleyou
    Subscriber
    +1 for Osprey bladder – mine has a solid back which works well.
    I’ve had various things over the years but have always found Camelbak to the best. Bladders by themselves are really expensive though worth trying on eBay.
    jayx2a
    Member
    I think old Osprey ones had the solid backs – new ones do not.
    Will have a look at their bags too!
    I think it depends on what you need for the rides you do :/
    I recently went from a Deuter (with a Camelback bladder) to a EVOC (with a Camelback bladder) something 10L and then sold that on and bought the EVOC 20L Enduro thing (had great storage plus good back protector etc for me) and that uses said Camelback bladder but I did notice it had a pinhole so fixed with a stick on patch.
    My riding partner has a Osprey and swears by it and my older Camelback Mule did a good job but wasn’t made particularly well.
    James
    Premier Icon markoc1984
    Subscriber
    Some of the new Osprey range still have the solid back, I bought a replacement a month ago and it has a solid back. I think it’s 2 and 3 have solid backs, and 1.5 and 2.5 have soft backs.
    mikewsmith
    Member
    Uswe packs not a fan of the bladder though
    Premier Icon sparksmcguff
    Subscriber
    Osprey. Just work very well. Good quality plastics too so can stand a degree of misuse/abuse. Bladders available fairly widely.
    winston
    Member
    Used a few brands over the years but Camelbak has always worked well for me. Currently rocking a Skyline most rides which hits the sweet spot of size, comfort and very importantly, bladder accessibility. Also use an older Octane for shorter rides and running. The bladders just seem to last well and don’t taste bad.
    mikewsmith
    Member
    I’ll be putting a camelback bladder in my USWE, it’s the best bladder but the packs are just not quite there these days
    Premier Icon guandax
    Subscriber
    My Camelback Mule is 8 years old and still going strong. Gets three rides a week in all weathers. Tough as old boots.
    ceept
    Member
    I’ve been using an “aquatic way” bladder from Amazon for the last year or so.
    Its camelbak compatible (big opening), the tube removes from the bladder, which makes filling without getting the bag wet painless, and the bite valve is very similar to the camelbak one. I’ll buy the same again when I need another one.
    Edit.. Just looked, on amazon at least, they have rocketed in price. My 2l one was £8 in December 2017.
    Premier Icon garage-dweller
    Subscriber
    I’d avoid the budget option of the Decathlon bladders.
    <span style=”font-size: 0.8rem;”>The main bladder is ok but the new style bite valves on the two I bought are awful in use and leak constantly.</span>
    I’m going back to Camelback based on above.
    Used several reservoirs and stuck with Hydrapack.
    Camelbaks are good, but cleaning and drying is awkward.
    Osprey hard was uncomfortable (but is a brilliant idea).
    Hydrapaks don’t seem quite as well made as the newer Camelbaks (the better half uses a Camelbak), but the dry bag-esque closure makes them really, really easy to fill, clean and dry (and you can roll down a 3L res to fit space designed for a 2L bag). The detachable hose mechanism has varied in quality a little on the few I’ve had, but on the whole it works well; I also remove the bite valve after use to let both the valve and the hose dry. All in all it’s by far the easiest res to use I’ve come across.
    jayx2a
    Member
    I believe the Evoc packs are made by Hydrapack too.
    tuskaloosa
    Member
    EVAns is having a flash sale on Ospreys end today 20% off using OSPREY20
    <div>Could well be. They make them for Dakine and Ogio too.</div>
    Premier Icon benp1
    Subscriber
    Camelbak make the best bladders in my view. Have used one for years, although I rarely use a bladder these days
    Often use a pack, been using one for bikepacking recently – EVOC FR Enduro Blackline in the main
    Premier Icon kimbers
    Subscriber
    I like the hydrapak closure, but camelback bladders are tougher ime.
    Endura singletrack backpack is brilliant , light, stays in place, just enough space, tool roll & takes a back protector
    I can see why people like the hydrapak bladders.  The one I borrowed for Ard Rock had got a pin hole leak and put a litre of sticky SIS down my back.  I’ve never had a Camelbak leak from the bladder (yes from seals).
    Agree Camelbaks are a pain to dry but we just rinse ours with hot water and stick in the freezer.  They get disinfected before (if we remember) and after a week away when they’ve not been refrigerated.
    tdog
    Member
    Yes EVOC use HydraPak bladders which I find to be the best.
The topic ‘Best hydration packs/bladders?’ is closed to new replies.
