Best Bathroom Scale?.
Home Forum Chat Forum Best Bathroom Scale?.
Viewing 21 posts - 1 through 21 (of 21 total)
  • Best Bathroom Scale?.
  • trail_rat
    Member
    what surface are they sat on.
    Munqe-chick
    Member
    Don’t flipping bother.
    Gary_M
    Member
    I’ve had a set of withings scales for the past 6 months, working very well so far.
    huggis
    Member
    Laminate floor
    Premier Icon dannybgoode
    Subscriber
    How long are you leaving it before getting back on. Some electronic scales need a short period to ‘settle’ between readings. 60 seconds or so usually does it.
    If you get off and straight back on the results can vary significantly.
    If you keep them in a cupboard or the like again, always best to put them on the floor and leave 60 seconds or so before weighing.
    Danny B
    huggis
    Member
    Danny B. good advice! Will try that and see what happens.
    Premier Icon simon_g
    Subscriber
    Still very happy with my Withings wifi one. If you don’t have space to keep it out flat, then at least get the same spot each time – we have a tiled bathroom floor so easy to line up the same place every day.
    huggis
    Member
    Anyone got a good a set of scales? My Salter ones are hopeless, today they gave me 4 different consecutive readings varying by 6lbs.
    Wireless nice but accuracy & consistency most important!
    huggis
    Member
    Withings looks good. Assume you don’t need to do anything to log weight once setup?
    AdamW
    Member
    Nope, I got one. You just stand on it and it weighs you and sends off the result. If you are a similar weight to someone else it will show you a list of names and you change your weighting to point at the one you want.
    A few mins later and you can see the graphs online or on your iphone.
    Gary_M
    Member
    Once connected to wifi you can either just use the scale to view your weight or the app/website stores all your date.
    Basil
    Member
    My wife has just shown me how to “loose” pounds by moving our digital scales around the bathroom.
    Posted by Jim slimmer than I thought
    Another satisfied Withings customer here too.
    Premier Icon molgrips
    Subscriber
    Mine are rubbish. It keeps saying like 88kg even though I KNOW I must be nearer 70kg.
    Premier Icon annebr
    Subscriber
    You’re only fooling yourself fatty
    Subscriber
    NO I AM NOT!
    I got fourth place on a Strava segment today, I’ll have you know.
    cheekyboy
    Member
    We do not suffer bathroom scale, life in a Northern Pennine water catchment area is fantastic in so many ways !
    nealglover
    Member
    Are people really spending £90 on bathroom scales just because they send your weight to your iPhone and save you typing 3 numbers into a free app ??!
    Subscriber
    Note with the new Withings Scale – you need an iPhone or Android phone to set them up. If you go for the cheaper WS 30 model (that doesn’t calculate body fat%) the white ones are iPhone compatible only. Don’t ask me why!
    Now I know most people do have an Android or iPhone phone but some weirdos like me don’t!
    Danny B
    Subscriber
    No scales calculate body fat. Some make a wild stab in the dark though.
    Subscriber
    OK – I’ll rephrase. The WS30 does not take a wild stab at your Body Fat, the WSB01 and WS50 do.
    Regardless of the accuracy of the actual reading though, so long as you use the same scales to take the measurement it is a useful indicator as to whether you are getting leaner.
    Danny B
The topic ‘Best Bathroom Scale?.’ is closed to new replies.
