Formula Cura 2 pots:
-Easy to bleed, can be a bit messy when you pull the syringe off. Unlike Sram, they don’t need bleeding all that often, mineral oil is nicer to work with too.
-No noisier than other brakes in the wet
-Plenty of power, run 200mm rotors front and back on the big bikes, 180s on the trail bike. ABout the same as an XT 4 pot, except with modulation and no random bite point.
-Weight, on par with everything else.
I’ve got 3.5 pairs, never needed anything more than a bleed in the 3 years I’ve been on them
I’m yet to find a 4 pot brake that doesn’t have a lazy piston, random bite points, noisy and other stuff that just doesn’t happen with a 2pot brake.
