Yes and no. There are crap bearings out there and yes on ebay you could find many fakes. There are plenty of cheap bearings from a good bearing supplier local or online that are way cheaper than branded but are basically identical either in spec or are actually the same bearing make and model.
Hope branded are INA bearings anyway.
Important thing is the seal on the bearing. Match the codes and should be good. Though quality the hub/headset/whatever seal plays a bigger part. Good enough seal and the crud isn’t getting anywhere near the bearing anyway (something I’m impressed about with DT Swiss hubs).
Local bearing shop, or online. simplybearings.co.uk for example.
That said, the Hope kit can be reasonable value for money if you need all the bearings in the kit, depending where you buy them.
