If you drop Hope an email i’m sure they would tell you the part number for a bearing kit for the hub, you can then order one through your local bike shop so long as they stock hope stuff. Sonme online stores may have it listed as a kit already so it’d be woth a quick google.
Hope may tell you the bearing type fopr the needle roller bearing if it is not part of a readily available hope after market kit. You could also ask them if it needs replaces with the other bearings in a general hub service or is for the casette section.
Below is the bearing numbers for the specs listed (Hope give you a handy hint with there part numbers). The 2RS is the sealing on the bearing in this case 2x rubber seals (commonly used in MTB application)
17x30x7 = 61903-2RS bearing
15x28x7 = 61902-2RS bearing
If you google the bearing type rather than the spec you may find a better selection.
edited to actually make a little sense.
