As long as it’s not a carbon frame you can take it out and put it back in numerous times with a headset press/extractor. I’ve made a tool to do this easily from a few cheap bits and pieces from b and q. I’ve just fitted another one on friday which is why it’s fresh in my mind.
If it was fitted correctly with plenty of the loctite that is supplied with it if be really surprised if it was able to move inside the frame and cause a creak. <span style=”font-size: 0.8rem;”>Are you sure it’s the bottom bracket creaking? I’d check all of the other usual suspect like skewers, headset, bars and stem before going down that route. </span>
