just painted our back door, white gloss. masking taped the 6 small panes in the door but after peeling off its still quite scruffy around the edges, and shows some of the previous dark wood right in the corners.
the best way i can think of tidying it up is some thinnish bead/filler type strip that i just cut off and stick into the edges, so it looks like its been siliconed if you see what i mean? im sure if i attempted that (or caulk) itd look messy tho, using a gun in such small spaces and only wanting a thin bead, hence the idea of ready made strip that just pushes in.
its not external, theres a utility room beyond, so no need for weatherproofing, its purely cosmetic. (and yes that paint smudge on the glass has already been removed 😀 )
ive googled glazing bead, filler bead, glazing strip etc etc but not finding anything suitable.
That needs a seal between the bead and the glass and the paint should lap over it and just onto the glass. Water will go down the gap and your door will be ruined. Do not use caulk or silicon, use white CT1 or an over paintable all weather sealant (cut the nozzle end so you’re just applying a tiny bead of it, trim with a very sharp blade when set if required).
thanks, never heard of them but a bit of investigation sent me down a rabbithole of youtube vids. initially wondered why youd spend money on them when you could just snip the corner off an old credit card or something, but the vids seem to have won me over 😀
the youtube vids actually show a problem with them in that theyre too wide to go behind taps and the like? and i cant think of many silicone jobs that wouldnt have to negotiate taps.
matey seemed to use the fugi wiper, then for taps switched to a lolly stick type of tool which could fit behind the taps. so why not just use that in the first place?
seem pretty pricey tho for a few lolly sticks with a bit of plastic on the end…..
