TandemJeremy – Member
If you changed the pads and then the brake failed occams razor tells us that the changes you had made led to the failure in some way
First point – Occam’s razor doesn’t tell us that – it suggests that is the most likely reason. The simplest explanation isn’t always the right one.
From your old friend wikipedia
Occam’s razor (or Ockham’s razor)[1] often expressed in Latin as the lex parsimoniae, translating to law of parsimony, law of economy or law of succinctness, is a principle that generally recommends, when faced with competing hypotheses that are equal in other respects, selecting the one that makes the fewest new assumptions.
Regardless, I do actually agree here – the change of brake pads was likely the trigger but that doesn’t make it the OP’s fault – new pads often have more bite which could well have been the difference between the rotor being able to take the load and not.
If I was the OP, I’d be going back to the online retailer and seeing why they hadn’t told people about the incorrect arrow. If they didn’t know, I’d then be suggesting that they take it to whoever deals with Ashima/Ashima themselves to find out why they hadn’t told the shops.
I’d be after some compensation in this instance at a minimum for damage to the bike and any direct costs incurred as a result of the injury. Only reasonable IMO – not suggesting claiming post-traumatic stress or anything else frivolous but the fact is that the only way some companies take consumer safety seriously is by being hit in the pocket.
